Embedding a Part in a Clear Box
This tutorial will show how to embed a modeled part in a clear box for 3D printing and display.
Step 1: You will need
- a CAD modeled part (the original CAD file or STL)
- Materialise Magics
- GrabCAD Print
- a Stratasys 3D printer with VeroClear, Vero UltraClearS, or ElasticoClear material
Step 2: Import CAD Model into Magics
- Open Magics and select Open
Select your part from files
- Set import parameters
- Enter into Edit Mode
Step 3: Add a clear box
- Under Edit Mode, select Create to add a new part to the assembly
- Using the menu, create a box of any size (we'll rescale it in a second)
- After the box has been added to the assembly, use the Translate and Rescale features to adjust its size and orientation
- Toggle the transparency of the box in the Part List to adjust visibility
- Ensure your part is completely surrounded by the clear box
Step 4: Embed the part in the box
- Ensure that both parts are selected in the Parts List
- Select Boolean from the Edit tab of the main menu
- Using the Subtract feature, subtract the part from the box
- Note: Be careful not to unload the original part!
Using the Boolean Subtract feature will leave the box with a part-shaped hole in it that allows the parts to be printed as two separate bodies. This is also a great way to create custom fixtures as the resulting box will have the exact part as a hole.
Step 5: Export the part
- Now that we have the part ready to go, it is time to export it for printing
- Ensure that your desired parts are selected in the Parts List
- Navigate to Save Selected Parts As
- Select 3MF as the file type, and ensure that the setting is set to Save Parts to One File
Step 6: Import to GrabCAD
- In GrabCAD, ensure that the printer is a Stratasys PolyJet printer with clear capabilities
- Navigate to the Tray Settings
- Check the tray materials under Change Tray Materials, making sure that the printer is loaded with VeroClear, UltraClearS, or ElasticoClear
- Note: If your printer is not already loaded with a clear material, perform a material replacement wizard to change the material now.
- Use the Add Models button on the left-hand side of the menu
- Add the final 3MF file
- Note: If a "no volume" error occurs, there is likely a gap between your part and the box. Make sure not to move the part within the box after the Boolean is performed to avoid creating voids.
- If the part imports with Errors, navigate to the Part Analysis to repair all models
Step 7: Print!
- You're almost ready to print!
- Selecting just the box, use the Model Settings to change the material to VeroClear, UltraClearS, or ElasticoClear
- Change the color of your part using the Model Settings as desired
- For best results, set the box Finish to Glossy, and the part Finish to Matte
- Note: whichever face is on top, will print with the greatest degree of clarity. Printing with a J850 or J55 on glass will produce a greater surface finish for the side oriented to the tray. For more information on that process, click HERE.
- Finally, select print! Make sure to connect to your Stratasys printer and perform any necessary pre-printing tasks.
Step 8: Finishing (Optional)
There are a variety of post-processing finishing tasks that can improve the quality and surface finish of a clear part. For more information, check out the Basic Post-Processing Guide for PolyJet 3D Models on Stratasys' website.
