how do i hide all planes,constraints in assembly in CATIA ?
On menu line select EDIT, than on pop-up menu select SEARCH, than go to the tab ADVANCED. On this tab you choose the right parameters: i.e. planes and axis. Selection of more than one parameter must be done with boolean operator "OR". When the parameters are set, then you click SEARCH and after that you click SELECT. Now all desired features are selected and painted in orange (in assembly and in structure tree). Click HIDE command (pop-up menu "view" or icon on toolbar "view") and that's it.
Go to the tab ADVANCED. On this tab you choose the right parameters: i.e. planes and axis. Selection of more than one parameter must be done with boolean operator "OR".
