How to combine multiple solids in AutoCAD?
How to combine multiple solids in AutoCAD by using UNION tool.
If you have 2 or more bodies you have created separately you probably want to to combine them at the end of your work, in case when it is not an Assembly.
I have those three solids and I am gonna use simple tool to combine them to one solid (body).
However, the command in AutoCAD is called UNION, not combine like in Solidworks.
So go to HOME and click on the icon which I marked on the picture, or you can just type UNION.
It will ask you to select objects which you want to combine, so if you want to combine all
then select all.
And that is it, now when you click any of those object you combined it will all be one object.
Karajko CAD
