How to create a rim of an Audi R8 ?
    I put a plan of a rim and I put on the front and center, see how to add the plans
    http://grabcad.com/questions/how-to-create-a-car-surfaces-based-on-bmw-x6
    you draw the various sketches that I need and I am an extrusion part cerculaire
    here is the result
    you draw a sketch on the right plan with a construction line ;
  5. Step 5:
    I make a circular surface along the line construction
  6. Step 6:
    here is the result
  7. Step 7:
    you create a sketch on the right plan
  8. Step 8:
    you create an extrusion to the surface
  9. Step 9:
    You can hide the face
  10. Step 10:
    here is the result
  11. Step 11:
    you create a sketch on the front like in the picture
  12. Step 12:
    here is the result
  13. Step 13:
    and you make a circular repetition
  14. Step 14:
    here is the result
  15. Step 15:
    you make a body on the exterior surface
  16. Step 16:
    here is the result
  17. Step 17:
    you do the same for the interior face
  18. Step 18:
    here is the result
  19. Step 19:
    after you leave the edges
  20. Step 20:
    you draw a sketch on the right plan with a construction line to the removal of the material
  21. Step 21:
    here is the result
  22. Step 22:
    you draw a sketch on the front plan
  23. Step 23:
    you draw a sketch on the front to have a spherical
  24. Step 24:
  25. Step 25:
  26. Step 26:
  27. Step 27:
  28. Step 28:
  29. Step 29:
  30. Step 30:
  31. Step 31:
  32. Step 32:
  33. Step 33:
  34. Step 34:
  35. Step 35:
  36. Step 36:
  37. Step 37:
  38. Step 38:
  39. Step 39:
  40. Step 40:
  41. Step 41:
  42. Step 42:
  43. Step 43:
  44. Step 44:
  45. Step 45:
  46. Step 46:
  47. Step 47:
  48. Step 48:
  49. Step 49:
  50. Step 50:
  51. Step 51:
  52. Step 52:
  53. Step 53:
  54. Step 54:
  55. Step 55:
  56. Step 56:
  57. Step 57:
  58. Step 58:
  59. Step 59:
  60. Step 60:
  61. Step 61:
    e end of our rim I import the model to KeyShot
  62. Step 62:
    and I do a rotation as seen in the picture
  63. Step 63:
    and I apply a material
  64. Step 64:
    here is the result
  65. Step 65:
  66. Step 66:
  67. Step 67:
  68. Step 68:
  69. Step 69:
  70. Step 70:
  71. Step 71:
  72. Step 72:
  73. Step 73:
  74. Step 74:
  75. Step 75:
