How to make a rendering with SolidWorks
Step 1: Select your file
First go, and select open a file to find your poryect
Select your file to render
now you have to piece in solidworks
Step 2: Use the Photo View 360
select photo view 360
Now we have all the tools to make a good render
Step 3: Choose a color
To give a color to our piece, select edit appearance
Now you can salect many colors, and diferent materials such as plastics, metal, glass, etc
In this case I´ll select materila plastic, and color blue
Step 4: Make a Scene
Now I´ll add a scene to make mor realistic the poryect
To do that, select the tool edit scene
Now you have this menu
You can salect many scenes to make more realistic your poryect
I Select a basic scene, 3 points beige
to add the scene , you only have to do a double click over the scene
Step 5: Final step
Move your piece to give a correct orientation
for example I orient miy piece in that direction
The next step is to use the tool final rendering
select add a camara
in this step you can select the orientation of the camara
finaly we have our render
Render
