How to make holes on a curved surface in NX that patterns around the curve
i used 2 workplanes and 1 extrusion
create a work plane with the wanted angle. i used the origin yz plan and rotated it around Z axis in the example i used 30 deg witch is not exactly the same as the surface but close. you as the drawer will probebley know the angle or you can messure it.
use this plane to create another on the right ofset in my case 0.75inch
create sketch on 2nd workplane and use project geometry as reference
create a circle and extrude use normal circular patern to patern done
