How to Make Turbine Runner in SolidWorks by Using Guide Curves in Loft Command
In this SolidWorks Video tutorial you will learn how to design francis turbine runner in solidworks, I will use loft command to make francis runner and for that first I will make two profiles at different planes and then I will make two splines in 3D sketch which I will use as a guide curve in loft command.
