How to model Letter Balance in Solidwoks - Assembly
Letter Balance - Fully Defined
Before start the assembly, copy Little bolt four times with diferent names
    Create a new assembly and insert the Stand on this position
    Insert a Right scale
    Use Mechanical mates Hinge with this references and values
    Insert a Left scale
    Insert a Large scale
    Use Standard mates Concentric with this references
  5. Step 5:
    Use Standard mates Coincident with this references
  6. Step 6:
    Insert a Little bolt 1
  7. Step 7:
  8. Step 8:
    Parallel mate this twoo planes
  9. Step 9:
    Coincident mate this twoo planes
  10. Step 10:
  11. Step 11:
    Insert a Little bolt 2
  12. Step 12:
  13. Step 13:
  14. Step 14:
    Insert Little scale
  15. Step 15:
    Other holle the same
  16. Step 16:
  17. Step 17:
    Insert a Little bolt 3
  18. Step 18:
  19. Step 19:
  20. Step 20:
    Insert a Little bolt 4
  21. Step 21:
  22. Step 22:
  23. Step 23:
    Insert a Left hinge
  24. Step 24:
  25. Step 25:
  26. Step 26:
    Insert a Right hinge
  27. Step 27:
  28. Step 28:
  29. Step 29:
  30. Step 30:
    Insert a Bolt
  31. Step 31:
  32. Step 32:
  33. Step 33:
    Insert a Right crank
  34. Step 34:
    Insert a Left crank
  35. Step 35:
    Insert a Top
    Use Standard mates Coincident and mate this twoo planes
  36. Step 36:
  37. Step 37:
    Use Standard mates Tangent and mate this twoo faces
  38. Step 38:
  39. Step 39:
    Use Standard mates Coincident and mate this twoo faces
  40. Step 40:
  41. Step 41:
    Insert a Upper hinge
    Use Advanced mates Width and mate it with this references
  42. Step 42:
    Use Standard mates Distance and mate this twoo faces
  43. Step 43:
  44. Step 44:
    Edit the Stand part and create a new plane with this references
  45. Step 45:
    Use Standard mates Limit Distance and mate it with this references
  46. Step 46:
    The Assembly must be Fully Defined
