Isometric - 1 Design in Siemens NX | Beginner Tutorial Siemens NX 1926 | #NX
This video will introduce you to some of the easy and basic concept of an Isometric design in NX 1926. This is a Beginner Tutorial in CAD design that will help you start a great path in Siemens NX CAD learning and Expertise. I hope you enjoy this Video
Siemens NX 1926 software is an advanced high-end CAD/CAM/CAE 3d Modeling Tool. It is also a flexible and powerful integrated solution that helps you deliver better products faster and more efficiently. NX delivers the next generation of design, simulation, and manufacturing solutions that enable companies to realize the value of the digital twin.
Learning NX just like any other CAD software is super easy and user-friendly.
It is used, among other tasks, for:
• Design (parametric and direct solid/surface modelling)
• Engineering analysis (static; dynamic; electro-magnetic; thermal, using the finite element method; and fluid, using the finite volume meth
Step 1: Making an Isometric Model in NX
