Learn Revolve Command in Solidwork software
how to use revolve boos command in solid work software.
Revolve boos command work on a close sketch.when your sketch is than you easy to apply this command. For example when you required a cylinder than you make it using revolve feature.First you create a rectangle.Now you apply revolve feature on rectangle length than you get a cylinder those height is the length of rectangle and breath is the radius of top and bottom circle. And now you revolve using breath than you get a disk.
guys if you want this video in English than comment I will try to provide as soon as possible.
