Metal Chains Design in Siemens NX 1926 | Swept & Pattern Tool Tutorial | Design in NX #NX
In this video, I will be using the Linear and Path Pattern along a curve or Sketch Command to design this metal chain in Siemens NX 1926 in less than 10mins. This video will also show you how to use the swept command under the Surface tab in NX.
This video will introduce you to some of the easy and basic concept of an Isometric design in NX 1926.
Learning Isometric design in CAD is an easy and quick way of becoming familiar and mastering any CAD software
Lessons in this Video:
- Fillet in Sketch
- Rapid Dimensioning in Sketch
- Swept Tool/Command
- Using Tangent Geometric Constraint
- Along a Curve/Sketch Patterning
-Linear Pattern
-Making a chain design
- Using feature Color
Video Timestamps:
00:00 - INTRO
00:22 - What We Will Be Designing
00:29 - Beginning of Tutorial - First NX Sketch
01:05 - Using Fillet in NX
02:35 - Rapid Dimension use in Sketch
04:02 - Using Swept Command in
Step 1: Chain Design
