NX One Step Analysis
Hello everybody...
Welcome to Mech Dezignz...
Today we will learn about solving a blank of 3D model in NX...
So I have a sheet body in NX window behind...
First we will have to take middle surface of the part by offset command...
Lets start...
So here thickness in 2.5mm.
so we will offset the surface at 1.25mm...
So we have got the middle surface as required.
Now for unforming a blank, we have a command One Step Anaysis in NX.
So we will go to the said command now...
And we select the middle surface of the part
Now we will select the vector from which direction the unforming is needed...
We also selected the material and provided the thickness of the part also...
We can reduce the element size for more precise blank shape, but then time process will increase...
Now since it is called one step analysis,
we get many more results along with blank shape that is
Thickness, Stress and Strain reports of the part.
This will let us know about the feasablity of the part as well...
Hope you liked the video
If any query, please comment down...
Thanks...
Step 1: Please watch this video:
