Solid Edge Tutorials | How to use swept protrusion command
Solid Edge Tutorials - How to use swept protrusion command
FOR MORE tutorials, please visit: https://www.youtube.com/c/CADCAMLearning?sub_confirmation=1
Step 1: Video tutorials show How to use swept protrusion command
This video tutorials show How to use swept protrusion command
Step 2: Sweep Options dialog box
On the Sweep Options dialog box, select a method for creating the sweep.
You can create swept features using a single path and cross section or multiple paths and cross sections.
Step 3: Defining the sweep path
On the command bar, select a method for defining the sweep path.
You can draw a path, select part edges, or select sketch elements.
Step 4: Define path curves
To define path curves, do one of the following:
- If you are drawing a path, define the profile plane you want to draw it on, and then draw the path or copy a path into the profile window. When drawing paths, you must click the Finish button after drawing each path
- If you are using part edges to define the path, select the edge or edges you want to use, and then click the Accept (check mark) button on the command bar
- If you are using sketch elements to define the path, select the sketch elements you want to use, and then click the Accept (check mark) button on the command bar
Step 5: Next button to select Cross Section Step
To define cross sections, do one of the following:
- If you are drawing a cross section, define the profile plane you want to draw it on, and then draw the path or copy a path into the profile window. When drawing cross sections, you must click the Finish button after drawing each cross section
- If you are using part edges to define the cross section, select the edge or edges you want to use, and then click the Accept (check mark) button on the command bar
- If you are using sketch elements to define the cross section, select the sketch elements you want to use, and then click the Accept (check mark) button on the command bar
Step 6: Define cross sections
- If you are drawing a cross section, define the profile plane you want to draw it on, and then draw the path or copy a path into the profile window. When drawing cross sections, you must click the Finish button after drawing each cross section.
- If you are using part edges to define the cross section, select the edge or edges you want to use, and then click the Accept (check mark) button on the command bar.
- If you are using sketch elements to define the cross section, select the sketch elements you want to use, and then click the Accept (check mark) button on the command bar.
