SpaceClaim basic tutorial - variable spring
SpaceClame basic tutorial - how to make variable spring
1.open new design
2.draw circle
3.draw line
4. select pull
5. select revolve -
6. select line
7. select circle ( select surface, not circle line)
8. select revolve helix -
9. taper angle: 30
pitch: 7 (if circle diameter is less, in this example, circle is 6 mm)
height: 14
10. enter or click in the empty -
11. taper angle:30
pitch: 20
height: 50
12. enter or click in the empty -
13.taper angle: -30
pitch: 20
height: 50 -
14. taper angle: -30
pitch: 7
height: 14 -
