Time Saving Tricks Using Sketches (Part 2)
Sketch plane: When editing the sketch plane, you can move your sketches from one plane to another. This is a great trick to know when you change your mind and decide that a sketch should be on a different face or plane. Simply edit the sketch plane to relocate the sketch instead of recreating it.
Step 1: Create a sketch geometry on one plane.
Step 2: Right-Click and Select Edit Sketch Plane.
Step 3: Select a Different Plane.
Step 4: Readjust Sketch to the Different Plane
Did you enjoy this time-saving tutorial? Watch the full video tutorial here and learn more about using the sketch plane tool to reuse sketches
