Tolerance Analysis and Tolerance Stack-Ups in Inventor
#Inventor #AutodeskInventor #ToleranceStackUp
Hi, In this video I will show you how to use tolerance analysis and tolerance stack ups in inventor 2019 and beyond.
The "tolerance analysis" add-in allows you to do a one dimensional analysis of a bunch of different parts in an assembly with either similar, or dissimilar materials. Once you add the tolerance zone for each part, you can view your results as either worst case scenario, RSS, Cpk, Etc.
Doing so gives you a good understanding of the tolerance of the whole assembly.
#AutodeskInventor
#Autodesk360
#AutodeskInventor2019
