Tutorial - Creating hex nut in SolidWorks?
Here is the tutorial.
Start Solidworks in Part mode.
Top Plane>>Sketch and make this sketch.
Extrude it by 7mm.
Click the upper face and then sketch.
Choose normal to view.
Make a circle tangent to the side of the polygon.
Under features tab choose extrude cut.
Check flip side to cut and draft enabled at 60degrees.
Click OK and we have rounded edges.
Repeat the same step for bottom face.
Step 11:
Under fillet choose chamfer.
Step 12:
Select the circular edge on the upper face, Change the length to 1mm and angle to 45degree.
Step 13:
We have now chamfer created.
Step 14:
Repeat the same step for the lower edge.
Step 15:
Under Features tab>>Reference geometry>>Plane and select top face and enter a distance of 10mm which is default value.
Step 16:
Choose plane1 and then sketch.
Step 17:
Normal to view and then select the inner cirular edge of the cylinderical face and then convert entities.
Step 18:
Exit the sketch and under features tab choose Curves>>Helix and spiral.
Step 19:
Change the configuration to height and pitch. Enter height of 27mm and pitch value of 1.75mm and click ok to create a Helix.
Step 20:
Choose front plane and then sketch.
Step 21:
Draw a profile of Equilateral triangle of side 1.7mm (less than pitch value) having one point coincident to the edge and symmetry.
Step 22:
Exit Sketch and Select Swept cut in Features tab.
Step 23:
Select the triangular sketch as the profile and the helix as the path for swept cut.
Step 24:
Click OK and the cut is performed. Now hide the plane1.
Step 25:
The Hex nut is created.
