Tutorial - Curve driven pattern in SolidWorks?
Here is the Tutorial.
Start SolidWorks in Part mode.
Top plane>>sketch and draw a circle of 140mm dia.
Extrude it by 10mm. Select the top face and sketch.
Make a circle of radius 5mm.
Extrude cut it.
Top face >>sketch.
Draw a spline from the center of the circular cut.
Select curve driven pattern.
Select spline as the direction1.
Select extrude cut as the feature to be patterned.
Step 11:
Check equal spacing and no. of instance to 4.
Step 12:
Click OK and we have the curve driven pattern.
