Tutorial - Designing ATV tyre in SolidWorks?
Here is the Tutorial.
    Start SolidWorks in Part mode.
    On right plane sketch this profile.
    Exit the sketch. Now under feature tab >> reference geometry >> axis.
    Select front plane and origin.
  5. Step 5:
    Now revolve the profile along the axis.
  6. Step 6:
    Reference geometry>>plane>>top plane by 140mm.
  7. Step 7:
    On plane1 sketch the XX using the text tool. Change the font size to make it a little larger and adjust the settings of the text. If needed use a center line as a curve for text.
  8. Step 8:
    Under features tab choose extrude. Choose extrude type Up to surface and select the surface of the tyre. Uncheck the merge result.
  9. Step 9:
    Under surfaces choose offset surface.
  10. Step 10:
    Select the tyre surface. Remember if we have merged the XX body in the tyre than this surface would have been trimmed. Click OK.
  11. Step 11:
    Under surfaces tab choose cut with surface and select the offset surface and select the selected body>> uncheck the autoselect and select the XX body.
  12. Step 12:
    Click OK and we have the cut performed. Now hide the offset surface.
  13. Step 13:
    Now Select the circular pattern.
  14. Step 14:
    Select the axis and the XX body to be patterned and no. of instances be 20.
  15. Step 15:
    Click OK and we have the first half of the tyre.
  16. Step 16:
    Select the Mirror in features tab and select the front plane and then select all the XX bodies to be mirrored.
  17. Step 17:
    Click OK. Now goto Insert >>features>> combine.
  18. Step 18:
    Operation type - add. And Select all bodies to combine.
  19. Step 19:
    Click OK and we are done. Though this is not as good as last one i made.
