Tutorial For Base and Seat Connector
This is a step-by-step tutorial for making Base and Seat Connector. This design is made for Visualization and Modelling class.
Vegantra Amayko Siaga
2106658811
Step 1: Make a Circle
First we make a circle in 2D Sketch with diamater of 10mm
Step 2: Extrude The Circle
Next we extrude the circle with length of 50mm
Step 3: Make a Half Circle Sketch in The Top Surface
Go to 2D Sketch again in the top surface of the cylinder and make a half circle of diameter of 20mm with arc and line.
Step 4: Revolve The 2D Sketch
Next revolve that 2D Sketch and change the angle A to 180 Degrees
Step 5: Make a Rectangle
Next the insert a plane above the half ball and start 2D Sketch of rectangle with 22,04 mm length and 4 mm witdh
Step 6: Extrude The Rectangle
Next we Extrude the rectangle by 5,8 mm downward and select Cut in the Output option
So, the model will look like this :
And that's all the tutorial for Base and Seat Connector model. I hope this tutorial can be helpful. Thankyou.
