Tutorial how to make engine part 10
cylinders
    open a sketch on right plane and draw a axis for new plane
    create a plane that have to be 35 degree between new plane and right plane. then open a sketch and draw 4 circles
    draw two circles like shown
    use mirror command two times
  5. Step 5:
    finally make your sketch like this
  6. Step 6:
    use extrude commad
  7. Step 7:
    open a sketc under the body and draw two circles. smaller circles radius is 50mm. other one have to be bigger then body. then use cut extrude command and enter volues
  8. Step 8:
    open a sketch on cutted surface and draw circles like this
  9. Step 9:
  10. Step 10:
    use extrude command
  11. Step 11:
    use linear pattern command. you must to decide that how many cylinder you want. I prefered to make 12 cylinder.
  12. Step 12:
    now we will cut the surplus portions. please check the photo and try to draw a sketch on the body like this. you should use linear pattern command
  13. Step 13:
    use the command and cut the body 70mm. That's all for now. please follow the tutorial step by step. if you have a problem with the tutorials please let me know
  • Anand Panchal
    Anand Panchal 23 Jun, 2017 12:43 PM
    Please Provide the Dimension For Extrude.
  • Rasim Zeytunlu
  • Mitja Gaberšek
    Mitja Gaberšek 16 Jun, 2018 07:32 PM
    What's radius on step 9? I haven't figured it out and I'm getting different results on part 11.
  • Michael Z
    Michael Z 1 Nov, 2018 10:05 PM
    Step 2 is vague. Please reword.
  • Runjie  Wei
    Runjie Wei 26 Dec, 2019 10:09 AM
    please reword step 2 it really not clear
