Tutorial: How to make engine part 41
Intake and Exhaust Valve Nails
open a sketch on the front plane
draw a centerline and line
continue the sketch
finish your sketch like shown
use revolve command
open a sketch bottom of the body
draw a center rectangle
use cut-extrude command
open linear pattern command
select the shown edge for direction
Step 11:
enter shown values
Step 12:
save the "intake valve nails"
Step 13:
click on the linear pattern. dimension appears
Step 14:
change the 40mm dimension. make it 30mm
Step 15:
use save as option and save the "exhaust valve nails"
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-42
