Tutorial: How to model parametric 3D text in PTC Creo Parametric and show design intent
Here is the short tutorial for you:
Create base shape (Extrude feature = create your model)
Create new Parameter (string) and set custom value (GRABCAD) >> Ok
Create new Extrude feature >> in Sketch mode create Text >> (set) Use parameter >> Select Parameter... (button) >>> Insert Selected custom parameter from the list
Note: 3D text is now parametric driven
Finish Sketch and set value for Extrude feature
You can use Auto Round feature
Set custom value for Auto Round feature
System create Round feature for all edges
If you need to change 3D text ... you can select Parameters >> and set custom value for text Parameter.
Regenerate model = you can use CTRL+G
3D text is parametric driven - you can see new value from parameter
