Tutorial: How to use drafting workbench in Catia V5?
Tutorial to use drafting workbench in Catia V5.
    Open the model for which drafting is to be performed.
    Switch to drafting workbench
    A new drawing wizard opens up. Choose the appropriate option. Here i chose a blank page.
    Window->tile vertically
  5. Step 5:
    You will get a view as shown.
  6. Step 6:
    Click on front view from the menu
  7. Step 7:
    Or get it from
    Insert->views->projection->front view
  8. Step 8:
    Click on the face as shown.
  9. Step 9:
    Place it on the blank page.
  10. Step 10:
    Click anywhere on the page.
  11. Step 11:
    Click on front view again. Choose a different plane.
  12. Step 12:
    Similarly drag and drop it on the blank page as in the previous case. Similarly get other views also by selecting different planes.
  13. Step 13:
    Right click on the drawing-> properties
  14. Step 14:
    Select the options as per requirement-> click OK
  15. Step 15:
    Edit->sheet background
  16. Step 16:
    Insert-> Drawing-> Frame and title block
  17. Step 17:
    Choose the title block->apply->ok
  18. Step 18:
    Insert->geometry modification->transformation->scale
  19. Step 19:
    Uncheck duplicate mode- Select value->ok
  20. Step 20:
    Edit->working views
  21. Step 21:
    Save as->*.catdrawing
