Tutorial - Making a bolt in Solidworks?
Here is the Tutorial. The attached file is the final output.
Start Solidworks.
Right Plane>>Sketch.
Make a polygon circumscribed with circle dia 18mm.
Extrude it by 7mm.
We have the extruded polygon.
On the right plane of the polygon start a sketch. Normal View to sketch.
Make a circle tangent to the sides of polygon.
Under features tab select Extruded Cut.
Change extrude depth to 7mm. The draft angle to 60degree and check the flip side to cut. Click OK.
Now you can see the polgon has rounded edges.
Step 11:
Repeat the same steps for the other face also.
Step 12:
Click on the right side circular face of the polygon and select sketch.
Step 13:
Make a concentric circle of dia 16.6mm.
Step 14:
Extrude it by 0.60mm.
Step 15:
Select the circular face of the extruded body in previous step and select sketch.
Step 16:
Make a circle of 12mm dia concentric to previous one.
Step 17:
Extrude it by 50mm.
Step 18:
Now we have the basic body of the bolt.
Step 19:
Under features>>fillet arrow>>Chamfer.
Step 20:
Select the circular edge of the bolt.
Step 21:
Change chamfer settings to 1mm distance and 45degree.
Step 22:
Now we have the chamfered body.
Step 23:
Select this face and sketch.
Step 24:
Under Sketch Tab choose convert entities.
Step 25:
Select this edge and then click OK.
Step 26:
Again click OK to exit convert entities.
Step 27:
Under Features tab>>Curves>>Helix and Spiral.
Step 28:
Choose Defined by Height and Pitch. Change the Height Value to 46mm and pitch value to 1.75mm keep other settings default.
Step 29:
Click OK and we can see that helix has been creted.
Step 30:
Top Plane>>Sketch.
Step 31:
Make a equilateral triangle of side 1.7mm with one point coincident to the edge of the bolt.
Step 32:
Under Features tab choose Swept cut.
Step 33:
Choose the triangle sketch as profile.
Step 34:
Choose helix as the path of the swept cut. Click OK.
Step 35:
Now we are done, we have the bolt created.
