Tutorial - Modeling Turbine rotor in SolidWorks?
Here is the tutorial.
Right Plane>>Sketch.
Draw this sketch.
Revolve it about center line.
Front plane>>Sketch.
Draw this profile.
Extrude it mid-plane.
Select top plane & origin and then click reference geometry>>axis.
Circular pattern.
Select the boss-extrude as feature to pattern about axis1.
Insert>>Features>>Flex.
Step 11:
Flex input be the body. Twist type and then enter 60º. Click OK.
Step 12:
Step 13:
Draw a circle.
Step 14:
Revolved cut it about the axis. We have the part.
show
Why are you cutting the blades at top? What's the purpose of that hole
Thank you bro
