Tutorial - Modeling USB Head in SolidWorks Part 2?
Here is the second part of tutorial.
    Inner face >> Sketch.
    Draw these center lines.
    Make angle of 50º.
    Offset them by .254mm in bi-direction.
  5. Step 5:
    Close these and trim away the lines.
  6. Step 6:
    Extrude it upto this surface.
  7. Step 7:
    Select this face >> Sketch.
  8. Step 8:
    Draw a center line and then a center point rectangle at the midpoint of the center line passing throgh origin.
  9. Step 9:
    Smart dimension it to 11.938mm horizontal and 4.064mm vertical line.
  10. Step 10:
    Offset the lines by .508 inside direction.
  11. Step 11:
    Extrude it by 11.938mm.
  12. Step 12:
  13. Step 13:
    Draw a rectangle.
  14. Step 14:
    Smart dimension it.
  15. Step 15:
    Mirror it about the center line.
  16. Step 16:
    Extrude cut it by through all.
  17. Step 17:
  18. Step 18:
    Draw a rectangle of 1.016mm height coincident to inside edges.
  19. Step 19:
    Extrude it upto the next surface.
  20. Step 20:
    Fillet tool.
  21. Step 21:
    Select all these edges and fillet them by 1.016mm.
  22. Step 22:
    Now fillet these edges by 1.016mm.
  23. Step 23:
  24. Step 24:
    Draw two center line about the quadrants of the circular edge.
  25. Step 25:
    Draw a rectangle to the .762mm of the center lines.
  26. Step 26:
    Convert the circular edge.
  27. Step 27:
    Trim the circle and the rectangle.
  28. Step 28:
    Extrude cut it from offset of 1.016mm and depth of 1.016mm.
  29. Step 29:
    Here is third part. http://grabcad.com/questions/tutorial-modeling-usb-head-in-solidworks-part-3
