TUTORIAL: Routing - Pipes and Tubes in Solidworks
I will make it in assembly
The first thing you should do.
select Tools - Add Ins - and select solidworks Routing
and select a design library - Routing - Piping - flange - choose one, here I use the slip on weld flange.
and select the configuration you want. here I am using the first
make your settings. then ok.
and will appear as in the picture, you can slide the line according your dimensions ..
after that the result will be like this, and forming pipe
then I added a flange back
then I added a back flange valves in part.
the same as that to step 6, and then click on flange face - right click and select add route.
Step 11:
and will display the image like this, then I will make the line manually, because it does not use the "auto route"
Step 12:
The line that I created manually. and it can do to suit your needs ..
Step 13:
and after the exit, the result is like this.
I hope this tutorial is useful for you to learn ..
thank you.
