Tutorial - Wrap feature in Solidworks?
Here is the Tutorial.
Start Solidworks.
Sketch>>Right Plane.
Make a circle let dia be 100mm.
Extrude it by 200mm.
Sketch>>Top Plane.
Choose Normal to view or press ctrl+8.
Make a centre line that passes through the axis and coincident with the centres of both the circular faces.
Choose Text in Sketch tab.
Choose the centre line as the curve.
Type in the text. For example GrabCAD.com.
Step 11:
Adjust the alignment (center) and the size of the text (let be 48mm).
Step 12:
Click OK and exit the sketch.
Step 13:
Choose Wrap in the features tab.
Step 14:
Select sketch2.
Step 15:
The wrap feature property manager will show.
Step 16:
Choose the cylinderical face.
Step 17:
Change the emboss height to 10mm.
Step 18:
Click OK. The Embossed text appears.
Step 19:
Click Wrap1 and choose edit feature.
Step 20:
Change wrap type to Deboss.
Step 21:
Click OK and you can see that this time the text is dugged into the cylinder.
Step 22:
Again edit the feature and this time choose Scribe.
Step 23:
Click OK and you can see the scribed sketch on the cylinderical face.
