ZW3D Pedal Crank Modeling Tutorial
This zw3d tutorial is show you how to create 3d pedal crank with some basic command, check it out!!!
  1. Step 1: Creating 2D Sketch
    In this steps we can learn how to create 2d sketch with dimension
    • Open your ZW3D software and click sketch, choose green plane (ok)
    • Use draw command to create 2d sketch, like image below
    • Next you can use quick dimension to change dimension of the object
    • To connect between line, you can use arc command with radius 11
    • Exit sketching and then we can convert into 3d solid
    • Use extrude command, select profile and extrude with 28 point
    • After it you can create circle sketch in face of the object
  2. Step 2: Extrude Cut With Profile
    We can use extrude with remove option to cut solid with circle profile
    • Click extrude, next select profile (circles)
    • You can click rectangle icon near profile options, then choose inside region of the circles (click ok)
    • After it you can use symmetrical and then give extrude point until create hole (ok)
    • The next steps you can extrude cut, with profile in region between 2 circle.
    • Give point -3
  3. Step 3: Use Fillet Command
    There are 4 different fillet radius for the object
    • Fillet with radius 12 in the back and front vertical edge
    • Fillet with radius 2 in top and bottom side edge
    • Fillet with radius 150, 100 and 4 in middle top and bottom
    • Fillet with radius 1 in the hole edges
  4. Step 4: Video Tutorial
