Electric Motorcycles & Electric Bicycles
Created by Steven Minichiello on 30 October, 2020
elektirikli motorum için akü sorunum var nerden bulabilirim ?
bir motor tasarımım var marka çıkarmaya oluşturmaya çalısıyorum fakat akü sorunum var yardımcı olur musunuz
Accepted answer
Translation in English for everyone : "I have a battery problem for my electric motor, where can I find it? - - I have a motor design, I am trying to create a brand, but I have a battery problem, can you help me? "
I would recommend that you post both the exact electric motor you have along with a model showing how you intend to use it.
If you are trying to locate a battery that will support your design, we can then try to help you. Otherwise describe your battery problem and we can discuss it.
1 Other answer
In your response you said "There are models on the internet, I need a battery that will accelerate it to 100 km/h with a TR unit and charge it to 100% in 4-5 hours max." and "Do you have any suggestions that can go 100 km on a single battery?"
So in order to understand your power consumption, and thus your battery capacity, the first thing that you need to do is figure out how much current is drawn from the battery when traveling at 100 km/h. This will also be dependent upon the load, how flat the travel distance is (any hills?), and whether the surface is paved or not.
Knowing your average current draw from the battery will enable you to calculate the capacity of the battery for the range that you need.
Charging is a separate issue and is related to the capacity (C) of the battery (in Amp*hours, the maximum charge rate (which is usually the same as C), and how much life you want from the battery. Remember that fast charging will internally heat up the battery and will shorten the life of the battery as well as reduce its long term capacity.
