The CAD files and renderings posted to this website are created, uploaded and managed by third-party community members. This content and associated text is in no way sponsored by or affiliated with any company, organization, or real-world good that it may purport to portray.
Circular Fastening (Hose Clamp)
__Info
3D printable circular fastening, cylindrical gripper, variable diameter connector, jubilee clip, hose clamp or adjustable radial constriction device that will grip firmly around a cylinder, a rod or pole - typically used to secure a hose to an outlet. Could be incorporated into other models.
__Sizing
The size in the filename of each mesh represents the interior radius of the hoop, when the fastener is printed and slightly open. This will fasten down to ~1mm less than the initial state at max.
Leave a comment or send a message if you'd like me to export some other size. I got about a third of the way to doing this in OpenSCAD before giving up, so it's not user parametrizable as of now.
Show more...
217 Downloads 12 Likes 1 Comments
Details
Uploaded: May 27th, 2023
Software: STL,
Categories: 3D printing, Fixtures, Piping,
More by inhabitant
Similar models
Files (7)
Loading
HoseClamp17mm.stl
stl
May 27th, 2023
HoseClamp11mm.stl
stl
May 27th, 2023
HoseClamp12mm.stl
stl
May 27th, 2023
HoseClamp14mm.stl
stl
May 27th, 2023
HoseClamp13mm.stl
stl
May 27th, 2023
HoseClamp15mm.stl
stl
May 27th, 2023
HoseClamp16mm.stl
stl
May 27th, 2023
Comments (1)
Elizabeth Abboud
By any chance could you export one with an inner diameter of 40 mm?
14 Apr 2025 3:27 PM
