The CAD files and renderings posted to this website are created, uploaded and managed by third-party community members. This content and associated text is in no way sponsored by or affiliated with any company, organization, or real-world good that it may purport to portray.
HOME THEATRE - BLUETOOTH SPEAKER SYSTEM 2.1 SONY - TANG BAND SUBWOOFER - 3D PRINTED - DIY
Its a fully 3D printed 2.1 Home Theatre Speaker system.
Sony 2way speakers & Tangband Subwoofer used.
200W amplifier Wuzhi MT21. 50+50+100.
Bluetooth 5.0 & AUX IN connectivity.
Temperature controlled cooling fan.
Able to adjust Treble, Bass, Subwoofer frequency & volume.
ENJOY
Free Step & Stl format available. Check the link below:
https://www.thingiverse.com/thing:5143737
PART LIST:
SATELLITE SPEAKER - 2 QTY
1. 3D PRINTED PARTS (LH & RH BOX, FRONT & BACK COVER)
2. SONY XS-FB102E (1 BOX CONTAIN 2 SPEAKERS) / (ANY 4" 2WAY SPEAKER (MODIFY SCREW PITCH HOLE) 50W+50W MAX)
3. SCREW M4 X 20 (AVAILABLE IN THE BOX) - 4+4 QTY
4. XT-60 MALE CONNECTOR - 2 QTY
5. SPEAKER TERMINAL CONNECTORS / SOLDER WIRE DIRECTLY.
6. INSTANT ADHESIVE GLUE, RUBBER GLUE ADHESIVE & DOUBLE SIDED TAPE.
SUB-WOOFER SPEAKER
1. 3D PRINTED PARTS (LH & RH CASE, FRONT COVER)
2. TANG BAND TB W5-1138SMF / (ANY "5" SUBWOOFER (MODIFY SCREW PITCH HOLE) 100W MAX)
3. SPEAKER TERMINAL CONNECTORS / SOLDER WIRE DIRECTLY.
4. XT-60 MALE CONNECTOR - 1 QTY
5. SCREW M4 X 20 - 4 QTY
AMPLIFIER
1. 3D PRINTED PARTS (CASE & COVER)
2. WUZHI ZK-MT21 200W / USE ANY AMPLIFIER 2.1 (150-200W) BUT CASE WON'T MATCH.
3. 40 X 10MM 12V DC COOLING FAN - 1 QTY
4. 2.1 X 5.5mm DC POWER JACK SOCKET FEMALE - PANEL MOUNT - 1 QTY
5. TEMPERATURE SWITCH 50 DEGREE CELCIUS NORMALLY OPEN (NO) - 1 QTY.
6. LM2596 DC-DC STEPDOWN BUCK CONVERTER.
7. XT-60 MALE CONNECTOR - 3QTY
8. M2.5 X 8 SCREWS 12QTY
9. INSTANT ADHESIVE GLUE.
FOR CONNECTION
1. SPEAKER WIRE 3M - 3 QTY
2. XT FEMALE CONNECTOR 6 QTY - CONNECT EACH END OF SPEAKER WIRE.
3. DC 12-24 V 16-10A ADAPTOR/SMPS.
3D printing
0.8 NOZZLE FOR BIGGER PARTS - 1.6 mm shell wall thickness 2 lines
0.4 NOZZLE FOR SMALLER PARTS - 1.6 mm shell wall thickness 4 lines
INFILL 10-20%
THIS PROJECT IS JUST FOR ENTERTAINMENT PURPOSE. I'M NOT RESPONSIBLE FOR ANY DAMAGES OR ISSUES FACED BY RECREATING THIS PROJECT.
Show more...
215 Downloads 40 Likes 0 Comments
Details
Uploaded: November 24th, 2021
Software: STEP / IGES, Rendering,
More by John P Jacob
Similar models
Files (7)
Loading
jpg
November 24th, 2021
SOUND SYSTEM FULL ASSY.stp
stp
November 24th, 2021
jpg
November 24th, 2021
jpg
November 24th, 2021
jpg
November 24th, 2021
jpg
November 24th, 2021
jpg
November 24th, 2021
Comments (0)
