Prime insert lock with 100% stainless steel mechanism. The stainless steel adjustable self-latching bolt and hook combined with the right keep guarantee a strong and solid closed gate where the gate wings can not be pulled apart or forced open. The lock can be installed on metal, aluminium and PVC gates. Thanks to the patented "Click-It" system, installing the lock can be done in a matter of seconds.
Specifications:
• Lock mechanism with cover plate against dirt penetration
• Patented "Click-It" system makes thread tapping unnecessary
• Continuous adjustment of the daybolt up to 10 mm without dismounting the lock box
• Backset 20 mm, for mounting in profiles of 40 mm depth or more
• Key-operated self-latching bolt
• Mechanism, hook, frontplate, latchbolt: stainless steel
• Easy left or right changing of the self-latching daybolt
• Throw of the hook: 21 mm
• Center-distance cylinder <=> handles = 92 mm
• Optional: cover shield for handle & cylinder holes in aluminium, polyamide or stainless steel
• Handles to be ordered separately
• Compatible with all Europrofile cylinders
Thanks for your most detailed models, very useful.
I believe that the STEP file for the forty lock is for the fifty lock. Would it be possible to obtain the Forty Lock one.
Regards
