Can someone convert a SketchUp file to SolidWorks or DWG or Step format?
I have a SketchUp file that I need to edit in SolidWorks 2017 (or older). I have only been able to convert it online to STL, but this format does not work for me. I will greatly appreciate if someone can convert it to SolidWorks or DWG or Step formats. From already thank you very much!
Accepted answer
1. go to the link https://fabconvert.com/convert/skp#google_vignette
2. Upload your .skp file and select the format you need to convert.
3. Download your file and open it with SOLIDWORKS
I tried this out on the file you attached, it worked for me
You can try any online converter.
0 Other answer
