Can the approximate weight of the solid structure be determined from the technical drawing and material specifications? P. Rohith Sai balaji 23 Nov, 2024 07:31 AM The structure is already grouted to the floor, and we plan to automate the entire process. 1 Answer WEGYAN Answered on 25 Nov, 2024 06:56 AM Yes, use simple formula Density = Mass/Volume or Mass = Density x Volume Calculate the volume of your structure and multiply with density of your material. (While calculating, make unit same in both physical quantities)
