How can adding symbols to a diameter dimension in catia?
I create a diameter dimension for a hole and would like to add the depth to the dimension using the depth symbol. Is this possible?
I've found the easiest way is to add a Text below (or after) the Ă˜dimension, and then you can choose the Depth symbol from the drop-down list.
