How to create a rope drive?
Here is my solution. In this the rope is just a part which don't work as in Assembly or we can say that for representation only.
Start SolidWorks in Part mode.
Right plane >> Sketch.
Draw this sketch.
Revolve it. Save this part.
New part. Front plane >> Sketch.
Draw a rectangle.
Extrude it.
Front face >> Sketch.
Draw three circles.
Extrude them.
Step 11:
Save this part.
Step 12:
Start a new assembly and insert this part.
Step 13:
Insert three part1.
Step 14:
Mate. Select this face of the pulley.
Step 15:
And this face of the part.
Step 16:
Generate coincident mate.
Step 17:
Select inner face of the pulley.
Step 18:
And the circular face.
Step 19:
Generate mate.
Step 20:
Generate similar mates for other parts.
Step 21:
Assembly features >> Belt/Chain
Step 22:
Select this face.
Step 23:
And this face.
Step 24:
And third face.
Step 25:
Enable Create belt part and click OK.
Step 26:
Click OK and save the assembly file.
Step 27:
Now the belt part is generated.
Step 28:
Open the belt part.
Step 29:
Reference Geometry >> Plane.
Step 30:
Select the line and the end point. Click OK.
Step 31:
Plane1 >> Sketch.
Step 32:
Draw two center lines.
Step 33:
Draw 4 equal circles tangent to them in each quadrant.
Step 34:
Trim the inner lines.
Step 35:
Exit the sketch. Swept boss/base tool.
Step 36:
Select the circle sketch as profile and the belt sketch as path.
Step 37:
Under orientation select twist along path.
Step 38:
Input no. of turns.
Step 39:
Click OK.
Step 40:
Window >> Assembly.
Step 41:
And we have rope drive.
