How to scale 3D objects in AutoCAD?
Tutorial about scaling in 3D in AutoCAD.
This is the random model I will use to show you the tool called 3D Scale.
You can find the tool on Home--->Modify--->3D Scale.There is also a Scale Gizmo option at Selection Panel.
I activated the command and selected the object.
Now I need to specify my base point,usually you want that to be somewhere in the middle,so I will select the start point of the gizmo.
Now I need to pick my scale plane or axis,whatever axis I chose it will be the same because I have base point in the middle.
Karajko CAD
