Tutorial - Creating knurl in SolidWorks?
Here is the tutorial.
    Start SolidWorks in Part mode.
    Top Plane>>Sketch.
    Draw a circle of 70mm diameter.
    Extrude it by 100mm.
  5. Step 5:
    Select chamfer tool.
  6. Step 6:
    Select both edge and chamfer it by 5mm at 45º.
  7. Step 7:
    Select the bottom face and then sketch.
  8. Step 8:
    Select the outer edge and then convert entity.
  9. Step 9:
    Select Helix and spiral under curves.
  10. Step 10:
    Change defined by to height and revolution. Enter 100mm height and 0.25 revolutions at 0º start angle. Click OK.
  11. Step 11:
    Top plane>>Sketch.
  12. Step 12:
    Select Polygon tool.
  13. Step 13:
    Enter number of sides 3 and draw it along piercing the helix. Exit the sketch.
  14. Step 14:
    Under features tab select swept cut.
  15. Step 15:
    Select the triangle as the profile and helix as the path.
  16. Step 16:
    Now reference geometry and then axis.
  17. Step 17:
    Select Top plane and origin as the references.
  18. Step 18:
    Now select circular pattern.
  19. Step 19:
    Select the axis as the parameter and the swept-cut as the feature to be patterned. Click OK.
  20. Step 20:
    Select mirror tool.
  21. Step 21:
    About Right plane or front plane mirror the circular pattern.
  22. Step 22:
    Click OK.
  23. Step 23:
    And we have the Knurl obtained.
