Tutorial how to make engine part 11
phil kight ,as per my method
    " U " section of lag 15mm make some blank space between chanal & cylinder surface.....(view fron bottom of cylinder)
    so i use " C " section of same dimention & sweep it at all around 6 cylinders & in other step extrud rectangle of " c " section's flat surface & extrude up to next surface...(as step 7).....
    after doing all this finaly u will get....
    in 3D
