Tutorial how to make engine part 11
Cylinders - 2
open a sketch on front plane and draw water canal profile
extrude it
create a plane bottom of body and use mirror command for to mirror water canal
after open a sketch on this surface
draw a sketch like this and use cut extrude command
go to left side, open a sketch and draw a sketch like this
extrude it. please attention that to make direction 'up to surface'. select the outer surface of the cylinder
open a sketch on same surface and draw semi-circular profile. it have to be closed profile
create the plane 3 ( it is at the center of water canal) then draw the path.( we will use sweep command)
use sweep command. then mirror it
Step 11:
create a inlet part like this
Step 12:
close the back side with your method
Step 13:
mirror all things and your water cooled 12 cylinders are ready
