Tutorial how to make engine part 17
Carter-2
draw shown sketch on the blue surface
use cut extrude command .
use extrude command. click on 'from surfacde-face-plane' option and select he green surface. then click on direction 1 'up to surface' and select the pink surface
draw shown sketch on the blue surface..
extrude the sketch up to pink surface
draw shown sketch front of the body
make same things again
draw a rectangle on the blue surface
use cut extrude command.
please follow next tutorial
