Tutorial how to make engine part 20
Carter connection points
use fillet command
after, make fillet this edges
draw a circle
use linear pattern command
cut the body
use mirror command
open a sketc on blue surface and draw a circle like this
use linear pattern command..
draw a centerline and use mirror command
use cut extrude command
