Tutorial how to make engine part 5
Crank oil canal
rollback the feature tree up to mirror1
use 3D sketch and draw a line. starting point and endpoint have to be center of the circles
delete the relations
enter z coordinate -5
enter z coordinate 20 for this point
add a plane ( referance geometry>plane then select line and endpoint)
draw shown circle on this plane
use cut extrude command
open a sketch on shown surface and draw a circle
use cut exturde command
Step 11:
now open a sketch on the green surface, draw a circle and use cut extrude command
Step 12:
open a sketch on the right plane and draw shown sketch. then use cut extrude command and cut the body
Step 13:
roll forward the feature tree and open a sketch on the right plane
Step 14:
draw shown sketch then use cut extrude command
Step 15:
use fillet command
Step 16:
crank is ready now
