Tutorial: How to use "bend part" feature in Autodesk Inventor?
Tutorial to use "bend part" feature in Autodesk Inventor.
Model a part and invoke a sketch on the surface about which you will bend it.
Create a line about which bending will initiate. Exit the sketch
Click on the arrow mark shown in the picture just below the "modify" tool bar.
Select bend part.
Select the bend line and other parameters.
Bend right will give the following result.
bend both will give the following result.
Flipping bend direction give result as shown.
You can change the bend type here.
Similar to above with bend radius increased. Click ok when finished.
