Tutorial: How to use emboss feature in Autodesk Inventor?
Tutorial to use emboss feature in Autodesk Inventor.
I'll be explaining to use this feature using a spherical model. However this can be useful in many other irregular surfaces also.
Create a plane offset from the original planes at a distance greater than the radius of the sphere.
Enter the dimension. Click OK.
Invoke a sketch on the newly created plane and click on "text".
Enter the text and format it according to your requirements. Click OK.
Position the text by using dimensions. Click ok.
Finish sketch.
Click on the emboss command.
Select the text as the profile. Click on "emboss from face",provide a depth,change the direction if required. click ok.
This is the result for "emboss from face"
Step 11:
Click on "engrave on face". click ok.
Step 12:
This is the result of "engrave on face"
Step 13:
Use "emboss from plane" .Provide a taper angle if required. click ok.
Step 14:
This is the result of "emboss from plane" . Hide the plane when finished.
