Tutorial on Modeling Bearing in SolidEdge
Here is the tutorial.
Start SolidEdge.
Click ISO Part to start part modeling.
The Part modeling workspace will show up.
Click Circle.
Enable all base reference plane for better plane selection. Now hover on XY plane and press F3 to lock it.
Keep the mouse pointer on the base and then click it.
Enter diameter 50mm and press enter.
Again select the circle.
Along X axis.
Draw a circle of 30mm.
Step 11:
Draw a circle of 30mm on other side too.
Step 12:
Click Smart Dimension.
Step 13:
Select Y-axis.
Step 14:
Select the circle.
Step 15:
Enter dimension of 35mm.
Step 16:
Repeat the same step for other circle.
Step 17:
Click Line tool.
Step 18:
Enable Tangent under sketching tab.
Step 19:
Draw a line tangent to the two circles.
Step 20:
Repeat the same step for other circles. If needed add tangent relation.
Step 21:
Select trim tool.
Step 22:
Trim all the inside elements.
Step 23:
Click Select tool and then click inside the region of the sketch and extrude it by 10mm.
Step 24:
Again select the circle tool and press F3 to unlock the top plane and then select the top face face and then lock it.
Step 25:
Draw a circle concentric to the middle circle.
Step 26:
Click inside of it and then extrude it by 28mm.
Step 27:
On top face click with circle and then draw a circle of 30mm.
Step 28:
Extrude it with remove at 6mm downwards.
Step 29:
Select circle tool and then click on the 2nd number top face
Step 30:
Draw a circle of 20mm dia.
Step 31:
Extrude it with remove material through all.
Step 32:
Select circle tool and then this face.
Step 33:
Draw two circles of 12mm dia concentric to edges.
Step 34:
Extrude both of them with remove and through all.
Step 35:
Enable right plane and then select Circle tool. Lock on the right plane and then along Z axis.
Step 36:
Draw a circle of 6mm dia.
Step 37:
Smart dimension it by 12mm to the top edge.
Step 38:
Extrude it with remove.
Step 39:
Through all.
Step 40:
And the part is complete.
