Tutorial on Modeling Bolt in SolidEdge ST4?
Tutorial.
Start SolidEdge.
Circle tool and then select origin.
Make a circle of 20mm diameter on top plane by locking it clicking on the lock icon.
Select Extrude.
Select the circle and then right click.
Extrude by 100.
Polygon tool.
Top face and then select the center of the edge.
Distance be 16.5mm and angle 0.
Select the region of the polygon.
Step 11:
While pressing the control key on the keyboard select the region on the circular face also.
Step 12:
Extrude it by 12.5mm.
Step 13:
Select chamfer equal setbacks.
Step 14:
Lower edge and input value 5.
Step 15:
Front view (Control key + F).
Step 16:
Draw a line along Z-axis of 85mm with endpoint at origin.
Step 17:
Polygon by Center.
Step 18:
Click the intersection of these two edges.
Step 19:
Input Distance 1mm.
Step 20:
Select helix under cut features.
Step 21:
Select the line.
Step 22:
Select the polygon.
Step 23:
Click Tick mark button.
Step 24:
Input turns 22.5mm. Right click to accept it.
Step 25:
Now go to the end face of the thread. Select the face and then project the edges.
Step 26:
Extrude it by remove at ~10mm.
Step 27:
Our bolt is ready.
