Tutorial: How to use rib feature in Autodesk Inventor?
Tutorial to use rib feature in Autodesk Inventor.
Invoke a sketch on the plane as shown.
Click on offset.
Select the rectangular profile.
Drag the mouse inside.
Provide the dimensions.
Click "finish"
Select extrude.
Extrude cut the profile created previously with offset function.
Provide the dimension. Click OK.
Invoke a sketch on the plane shown.
Step 11:
Create a profile which you want to rib. Finish sketch.
Step 12:
Click on "rib" feature.
Step 13:
Select the parameters as shown.
Step 14:
Select axisymmetric or any other option as per your need.
Step 15:
Select "finite" to rib the profile to a certain extent of a given dimension.
Step 16:
Select draft. Provide draft angle if you want. select which end to draft-top or bottom. Click ok.
